Shimano brake bleed with a sex toy :) hack
Good idea but I’ve been using another tool more easily accessible. An electric toothbrush. I’m sure your tool works wonders too.😉
I keep the electric toothbrush in the same tool drawer as the bleed-kit stuff.
If I do a full bleed I touch the calliper and exposed hoses also. A rotation of the bike and also the lever helps.
C’mon? Are you guys reading between the lines? 😮 that’s terrible.
Do you have air at the lever end whilst doing a bleed , then get yourself a SexySecret bullet vibrator and vibrate those pesky air bubbles away !
Genius , just clean it before giving it back to the other half :D
Is that “tool” made by Snap-On?!!
I saw a similar thing on tiktoktagram, where a guy used a massage gun on the brake line to eke out micro bubbles. I thought it was total bs but curiosity got the better of me and I have a massage gun already so I gave it a try.
I did my normal full gravity bleed on my XT front brake, then went back to perform a lever bleed.
After a few minutes there were no more bubbles coming through and the lever felt decent, but I then used the message gun to see if it would pull any more out.
Working from the caliper up, l spent a few minutes vibrating the line, gave the lever a flick and lo and behold LOADS of bubbles came through.
I Did this a few times and the lever has nerve felt so good! A little too good infact.
So it seems it may have some merit, but It's a shame you can only do it on the front line though.
    674K
