Bosch Powermore - fidlock mount mod?
RSG
Wales
Has anyone out there seen this being done before?
Would be interested to see if it’s possible somehow. Way prefer using fidlock waterbottles due to the clean look - would be awesome if there was a way to securely use a fidlock mount for the powermore battery to save having to faff and swap mounts over for rides where the extra 250wh is needed
You can get a bottle cage that clicks into the Powermore adaptor, here, though I do agree with you that the fidlock water bottles have a much cleaner look. Not sure whether the fidlock fixing would be secure enough, the Powermore battery is heavy and just a slight nudge from my leg on the side of a full water bottle will dislodge it for me!:unsure:
I believe like me he wants the Fidlock attachment to use with existing bottles when the Powermore is not attached, one that clips into the Powermore mount
I just finished modifying the bottle cage to become a fidlock base. Works perfectly for my application, which is the fidlock tool box. When I'm running the powermore battery, I'll also use a bigger hydration pack that will fit my tools... I used plastic cement and stainless rivets to mount the fidlock base to the bottle cage.
Pics.
Fidlock are showing a Bosch Powermore adapter at Eurobike this week, hopefully in the shops soon
Really? That would be great! My problem is I’m left-handed and the Bosch bottle holder adapter exits on the right… Not to mention I’ve been used to the convenience of Fidlock for years. Do you happen to have a link regarding this Fidlock adapter? Thanks a lot!
Yes, I contacted Fidlock about it but the lady said they didn’t know when they’d be available……
So do you still need to glue the female to the battery pack?
I don’t think ( and certainly hope ) any gluing is needed. The fidlock plate clips on to the PowerMore bracket on the bike, converting the PowerMore bracket to a fidlock mount for your bottle.
