SC-EM800 can’t switch to other screens.
Firetrack Rider
I have the following setup
EP801 - derestricted with eMax tuning
SW-EM800-L Assist switch works fine
EW-SW310 power switch - Works as expected
The problem is I can’t switch screens to show average speed, range etc.
It is stuck on KM/h and the button on the bottom does nothing except go into the settings if I hold it in.
What am I missing?
I got the answer. If it has been derestricted to an American class 3 it won’t show the other stats only speed. Look at *4 on this compatibility list under limitations.
Yeah with US Class 3 you can't change views on the em800 display for some reason. You would have to change to the 600 display and if you do that you also need the 600 switch and that is not exactly cheap.
Is that the sc-en600 or the sc-en610 since I already have the ew-sw310?
I have the same problem. When you set it to USA Class 3, it prevents you changing the screens. Switch it back to EU. And all the screens can be viewed. Must be a bug of de-restricting.
I run my phone on the bike with the E-Tube App, and just setup the data I want to display on the phone.
Edit. Just saw you found the answer. Nice. (y)
Yeah, I changed it to USA class 2 which is 32km/h and it works as well.
    674K
