Greetings, fellow riders!
XFi
Finland
Greetings from Finland! A fellow eMTB'er here, just wanted to say a quick hi.
Myself riding a Haibike but found the forum whilst searching for a way to fix (spouse's) Orbea Rise creaking issue. Found a comprehensive guide by @Rod B. There's a guy that does not spare the efforts on how-to's! 🍻
This forum seemed like the place to be as an eMTB owner, so here I am now :)
XFi,
Welcome to the forum. I hope you were able to fix the creaking issue with your wife's bike.
XFi,
Sure was, did the retaining compound trick for the splines to keep the arms from slipping. The drive side arm could be slid off easily with fingers without using any force at all after tightening the retaining bolt to the specified 15 Nm torque. There was no friction at all to keep the arm in place, even though the bike is almost new with less than 300 miles on the meter. Come to think of it, this kind of an issue might have been covered by warranty, maybe...
However there was additional clicking sound caused by seatpost that required re-lubing as well. Took away the seat and pushed down on the bare seatpost and found out that, indeed, the seatpost makes a clicking noise against the frame when pushed down.
Now she's silent, and spouse's happy.
XFI,
You made my day when I read your response. I'm glad I could help you out with my technical articles. I did a three part Shimano brake upgrade and maintenance series for the Gen 1 Orbea Rise if you are interested. Here is the link to Part # 1 in the series. Part Two in the series covers upgrading the brakes on the Rise. Part three discusses diagnosing brake pad/brake rotor wear and measuring your brake rotor for it's maximum wear limit (1.5mm).
Because you used the retaining compound, I doubt you will have any more issues with the linkage arms slipping. However, the compound if applied too thickly, can make it difficult to remove the lickage arms for a lubrication or bearing service. If you would like to avoid having to use the compound on a future service, there is now available a linkage arm preload and retention part for the Rise that is made by Cascade Components. The part prevents the linkage arms from splipping. I've attached a link below if you would like to look at the part.
Be safe,
Rod
and rotor
  • Like
Reactions: XFi
    670K
