which tires?
y0sh1mura
Spain
I'm lost with AllMountain/enduro tires for e-bikes.
till know i was an xco biker. Now with the amflow I don't know witch tires mount.
Dissector is sh1t. On maxxis tires Assegai and minion it's ok? Witch compund and Casing?
Assegai MaxxTerra DD and Minion DHR II MaxxTerra DD it's a good point to start?
Good choice of tyres. Personally, I would go for Assegai MaxxGrip DD on the front if available.? MaxxGrip maybe only available in DH casing.?
I ride Specialized Cannibal Grid Gravity casing which has T9 soft compound. More for aggresive steep trails (y)
Change Assegai to Maxxgrip and you have one of the best tire combo in the market. My favourite are also Contis Kryptos DH Supersoft and Schwalbe's gravity Alberts. Generally just go with DD/gravity casing tires and supersoft front tire and it's all good :D
Assegai Maxxgrip is available in DD, that's what we use.
Then Assegai and Minion both with Maxxgrip or Assegai Maxxgrip DD + Minion DHR II MaxxTerra DD ?
Yes. Assegai Maxxgrip DD. The softer compound will give you better levels of grip when braking especially on steeper trails & hold better on flatter corners.
Minion DHR II MaxxTerra DD for the rear. This compound will give you good grip but also last longer then the Maxxgrip compound especially as it gets all the drive forces going into it.
Assegai Maxxgrip DD - Front
Minion DHR II MaxxTerra DD - Rear
(y)
(y)
Done!! i'll try it
Im running the Maxxis high rollers front and rear, both max grip, exo + on front and DD on the rear, really liking them. The new Schwable radials are meant to be really good as well.
