Hey all, looking to upgrade the rear shock on my powerfly 4 fs gen 2, found a used one that I believe will fit. Any thoughts or suggestions?
Hi, did you upgrade, and if so what's it like.Hey all, looking to upgrade the rear shock on my powerfly 4 fs gen 2, found a used one that I believe will fit. Any thoughts or suggestions?
Heya, yep I did. I ended up changing the front fork to a rock shock gold 35 rl, and the rear to a fox evol dps. I used the bushings from the fox inside the stock sun tour bushings as the fox bushings are smaller. It was an easy job and made a huge difference.Hi, did you upgrade, and if so what's it like.
