YES!, but the web site say "M510 Motor"
They sent mine with the M560.YES!, but the web site say "M510 Motor"
Truth be told, I've not used (ridden) the M560 with M510 firmware.
Bafang have told me that they have no intention of releasing a 36v firmware for the M560, due to the maximum current requirements which can only be achieved with a 48v battery.
I guess it depends on the discharge rate of the battery. But logically, the range (especially on the Vitus E-Mythique) has been reduced.
I'm not at liberty to discuss upcoming products from Bafang at this time.Hello Neeko
It really works with 36V battery. Interesting.
Means it will be like 950W peak electrical, and same power as new Bosch. Which is not bad.
People can upgrade from 36V M500 or M510 systems to M560. If DYI battery then BMS simulation of course.
Dont you know some news from Bafang? Is there some new revision of M560?
You can ask them if they planning planetary gearing in M560.![]()
Is that rust on circlip and washer? Rust will increase the distance between the 2 and cause the fibre washer to bind is what I was thinking. Is water getting by pass the seal, how does the bearing sound?Well after 1200 miles it finally happened to me.
Went into the garage the other day and the bike was on with a code 36 on the screen. No one here turned it on. I was not able to turn it off with the button. I had to remove the battery to get it to shut off. I then reinstalled the battery and it would not turn on. I installed 2 different known good controllers and 2 different known good displays and it did nothing.
I pulled the motor out and apart. I found this on the PCB. No signs of water anywhere else.
Another thing that happened last ride was the motor became usually stiff to pedal backward. After pulling the motor out of the bike, it was very tough to turn the chainring spider by hand. After removing the spider I could not turn the spindle by hand. After pulling the motor apart, it contunied to be hard to turn untill I removed the torque sensor. Then it turned like normal.
When removing the torque sensor there is a c-clip;
Under that c-clip there's a fiber washer;
If I remove the fiber washer and reinstall the torque sensor it turns like normal. Its almost like the washer adds too much pressure on the sensor causing a bind. I'm at a loss.
No rust anywhere to be found in the motor. The only thing on the circlip and washer is the grease that's found in the motor. I found no traces of water anywhere. The first thing I did was check the bearings in the motor, I was secretly hoping that was the problem because its an easy fix. They all turn easy and smooth. The spindle turns smooth with the washer missing. As soon as I install it tightens back up.Is that rust on circlip and washer? Rust will increase the distance between the 2 and cause the fibre washer to bind is what I was thinking. Is water getting by pass the seal, how does the bearing sound?
Bum…I should have known it wouldn’t be that simple.No rust anywhere to be found in the motor. The only thing on the circlip and washer is the grease that's found in the motor. I found no traces of water anywhere. The first thing I did was check the bearings in the motor, I was secretly hoping that was the problem because its an easy fix. They all turn easy and smooth. The spindle turns smooth with the washer missing. As soon as I install it tightens back up.
I went through this when my battery died. Vitus is no help at all, not even a single reply. Bafang only wants to deal with the vendor that sold the bike and they are no longer in buisness. I am on my own with this.Have you tried getting hold of Vitus or Bafang? It appears they are currently trading again.
Maybe give these guys a ring, I’ve heard they are very knowledgeable.I went through this when my battery died. Vitus is no help at all, not even a single reply. Bafang only wants to deal with the vendor that sold the bike and they are no longer in buisness. I am on my own with this.
I ordered a PCB and will install that to see if it works again. I MAY install the torque sensor with no fiber washer just to see if it works or I might just put it together the way it was and see if it wears in. Not sure.
I received the PCB and swapped it in. Took it for a 12 mile ride and everything seems to be good. The tightness problem did not exist when it was put back together. I'm still unsure about that. I'm gonna continue to ride it and see how it does.Well after 1200 miles it finally happened to me.
Hey, I opened my M510 motor and all cables, boards, and connections look good. I have a new battery installed. It turns on, but I have an E30 error with a blinking battery icon. Then the display turns off at around 1min. I disconnected all cables and tried a new display and the same error come on. Any advice?My Vitus came up with a E30 fault code (communication error) I replaced the controller now it won't turn on at all! Does anyone know the battery out of sleep mode routine? Also has anyone had any luck with refunds now the company has gone? I brought the bike on paypal credit. Many thanks
Mine would not turn on again after trying a replacement controller. It is currently at a motor repair place but they say there having trouble getting response or parts from Bafang. The motor has been with them for about 6 weeks now.Hey, I opened my M510 motor and all cables, boards, and connections look good. I have a new battery installed. It turns on, but I have an E30 error with a blinking battery icon. Then the display turns off at around 1min. I disconnected all cables and tried a new display and the same error come on. Any advice?
Then try to swap that small PCB board with connectors. It is cheap. Also here can be that turn on/off issue.Mine would not turn on again after trying a replacement controller. It is currently at a motor repair place but they say there having trouble getting response or parts from Bafang. The motor has been with them for about 6 weeks now.
