Yes. the EM800 will work with the EP600 as shown in the compatibility chart from Shimano. It's not a better display than the EN600 in my opinion, but it does have bluetooth, which the EN600 does not. To get bluetooth with the EN600, you need to also buy the switch, SW-EN600L.So the EM800 is an even better display that'll work the bike?
You should have mentioned that. Yes. The SW-EN600 switch is normally paired with the EN600 display. The SW-EN600L switch has bluetooth. So you can pair a Garmin to it without any wiring modifications.Oh gosh, the rabbit hole. My new bike has the EN600 switch/lever. Does that make the 800 display not relevant? I need this Homer Simpson'd for me.
Right- so back to my question- is the en600 the way to go, or get a garmin bike computer that is compatible?You should have mentioned that. Yes. The SW-EN600 switch is normally paired with the EN600 display. The SW-EN600L switch has bluetooth. So you can pair a Garmin to it without any wiring modifications.
So the easiest modification is the Garmin.
To install the EN600 display. You need to re-route your SW-EN600 switch cable to the EN600 display when you install it. Then, the EN600 display has extra ports, which you run a new cable you must also buy, back across to the EN600 switch.
Yep. That's what I do. Just Hotspot.I do have an old iPhone in a drawer somewhere and some quad lock mounts. I don't want to pay for service, but maybe I can hotspot to my "good" phone that'll be in my pack.
