michael williams
what is the voltage coming out of the little yellow XT30 connector on a 36volt bafang BT F100 battery suppose to be?
When fully charged, it is about 41V.what is the voltage coming out of the little yellow XT30 connector on a 36volt bafang BT F100 battery suppose to be?
Got it, thanks a lot! I'd really appreciate if you share more once the issue is resolved. Good luck!Still trying to resolve the problem. Jim Lee has been working with me to find a solution. Can't say enough good about him.
As for the frame, it is very well done. The suspension just takes the edge off that jarring you get from a rigid frame. As I only got a couple rides in, I can only give first impressions. It handles quick and yet is stable when you are accelerating. One of my other ebikes is a BMC Alpenchallenge AMP which is full carbon with a similar rear suspension. The LC feels more stable at speed. On a personal note, I ordered another fork for it without the fin. Same fork, no fin. If you want to change brake pads on my shimano brakes, you must remove the caliper. Perhaps ordering with the other fork may be an option. I will offer more info when the battery issue is solved.
Any news with the bike? Would love to see some photos as well! Is there any drag with the motor when not using assist?Got it, thanks a lot! I'd really appreciate if you share more once the issue is resolved. Good luck!
