2025 Norco Range VLT BOSCH SYSTEM
Jeremybub
California
Hello all
just to give you a heads up on my experience with getting a range extender program to my 2025 Norco Range VLT Bosch system
First, I had to take it to the LBS and they had to submit an order to Bosch and Norco to update my firmware, allowing the range extender compatibility, this took about a week to complete
Second, I ordered the range extender cable, which is 100 mm
Last day works epic. I have 1000wh
The only issue is the bike weighed 60.3 pounds in a size 4 before the RE and now with the range extender it’s 62.7 pounds. However, the way the bike is set up it Pops like my 2024 carbon Levo which is 49.5lb.
anyways good luck to anyone going through this process.
FullSizeRender.jpeg View attachment 157180 View attachment 157181 View attachment 157183 FullSizeRender.jpeg IMG_1469.jpeg
How are you liking your Range? Anything you wish was different or would change? I am looking at the C2 and A1(found a great deal on both) of this same year and leaning towards the 3. I am 5'11"ish and 210lbs so high end of the 3 and low end of the 4. Thanks for any insight you can give me.
