Tow bar mounted bike racks
I am considering fitting a toe bar to my BMW and then using tow bar mounted bike rack. I intend carrying 2 EMTBS.
Looking at options I have short listed 2 racks and I am wondering if anyone here has experience of either one to help me decide.
Option 1: Thile EPOS 2 bike carrier
Option 2: Buzzrack Scorpion Pro 2.
The Thule is double the price of the Scorpion and highly recommended by BikeRadar so that plus the Brand...and price....suggest it is probably the safe choice...BUT is the much cheaper Scorpion just as good?
I've always had Buzz racks. Less refined than the German bling but never had any unexpected problems
Very strong with excellent quality welding. Carry 2 x Trek Rails (alloy) on our Buzzrack E-Scorpion 2 no probs.
thanks both. I suspect as you have said the Scorpion will do the job. In fact both myself and my son are in need of bike racks and he will buy the Scorpion based on your feedback. .....however I found a good deal on the Thule so I have decided to go for that one for myself. It will be interesting to compare them!!
@Mikerb I have a Thule tow-bar rack and its strong and well made.
The clamps are also good, but I've three times had problems with the clamp losing its grip on the bike. Two different bikes, both carbon fibre. Maybe I didn't tighten the clamps enough, maybe it was because I had some closed cell polyurethane foam in between the grips and the bike. Both down to my fear of crushing the carbon fibre frames as neither were round section. I tried the clamp above the top tube and also below the top tube. I can tell you that when you suddenly notice that your bike is not in the rear view and is dragging along the road, it's a heart stopping moment!
So how did I fix it? At first, I tied a leather strap around both, but I never felt comfortable with it, then in a local market, I found some rubber-covered wire-cored cable that could be wound in a figure of eight around the clamp and top tube. That really worked and I had 100% confidence in it. But it wore out in the end from all that bending and straightening.
Then I found The Mega Twist Gear Tie!
Nite Ize Gear Tie Mega Twist Tie - 32" - Orange | Outside.co.uk
Also available from Amazon.
They come in different lengths, but you will need the 32". I can carry two bikes on my rack, so I bought two of these. They last ages! Recommended for peace of mind.
I have one Thule EPOS 2 and one Thule EasyFold 2.
I have one eMTB with aluminum frame and one with carbon frame. I have used both bike racks with the carbon frame bike and both hold it well in place. I use the Thule carbon frame protector with the carbon frame. EPOS is probably safer since it grips around the frame.
Thule Carbon Frame Protector | Thule | United Kingdom
thanks for the tips Steve. The Epos 2 does not use jaw clamps but rather steel reinforced rubber ratchet straps (lockable) so I hope that proves to be a better fixing method.
I have a Thule Easy Fold XT 2 bike rack, used it with 2x emtbs and it's coped fine, just one point the easyfold has a low clamp height which can be tricky on some emtbs, my last bike and my existing one have both had to be clamped on the shock, if it is a problem then the Fiamma Bike Block Pro D1 works just as well as the Thule clamps
I have a 1UP USA and it is awesome! 75mph down the freeway and my EMTB hardly moves at all! I’ve owned it awhile and never had a problem.
I have the same Thule rack but am having real problems finding somewhere to clamp my Cube.
The top tube is too thick at the front and the rear shock is under the back.
I purchased the false crossbar from Halfrauds but it won’t fit around the top tube due to the small space and the cables going into the headset. Not sure what to do next.
Have you tried turning the bike around? Ring facing in instead of out for example. That will present different frame sections to the clamps.
Is clamping on the seat tube out of the question?
Might it help to dismantle the clamp where it fits onto the rack and move it from the horizontal tube onto one of the side tubes of the rack?
I assume that your clamps also twist.
This Thule model is symmetrical, so turning the bike will not change anything more than sliding the attachment a bit sideways.
I'm quite sure the problem is the use of foam for protecting the frame. The Thule Carbon Frame Protector is quite rigid.
Yes tried the clamps in different places And they do twist. Getting the bike home on purchase I seem to remember clamping the short seat post tube above the motor but now I have a bottle mount in there. Will have another look at the seat post but it’s a dropper and I wasn’t happy with clamping onto a piston.
I’ve just removed the clamps off an old Strada rack which are lockable ratchet straps and will fit the Thule frame so I will have a broddle with these. These don’t have the large locking knob like on the Thule.
Thanks for your reply.
The BUZZ RACK looks like it has a similar clamping method to my Thule Easy Fold XT. Its not ideal and struggles a bit with top tubes with a varying diameter - ie most emtbs. Also not great with Carbon bikes. I do have to be careful securing the bike on the rack. However once I have it on, and after I have stopped to check and tighten it once or twice, its is on and it ain't going anywhere.
The new Thule clamping system looks potentially a lot better. And annoying that there is no upgrade kit for my Easy Fold.
Best thing to do is watch a few youtube reviews of the racks you are interested in.
I also checked with the firm that fitted my tow bar before I bought the rack. My Easy Fold needs a good bit of clearance from the bumper, so getting the right tow bar is important.
your final point re clearance between bumper and top hitch is one that I also considered had been overlooked on tow bar online fitting services so rather than just booking online I send an email to request confirmation that whatever tow hitch was fitted would fit OK with my Thule rack
Had same problems on my Cube with Halfords crossbar, Decathlon one fitted well.
One other thing to check with tow bar mounted bike racks is maximum permiitted load.....not just for the rack but also nose weight on the tow ball. i have confirmed with my intended tow bar supplier that all the tow bars they install exceed the specification for the car's maximum nose weight.
So my rack ( Thule Epos 2 bike carrier) weights 17.5kg
The rack has a maximum carrier weight limit of 60 kg ( assuming carrying max load, nose weight on the tow bar is therefore 77.5kg)
My car ( BMW 520d) has a maximum towbar nose weight of 90kg
......so everything is within limits.
Are there no European racks that clamp the wheels instead of the frame? Similar to a Kuat NV or Yakima Stage 2? Way easier for modern MTBs.
Thule has come with a new version of EasyFold, EasyFold 3. The clip to attach to the frame is replaced a strap similar to EPOS. It will probably be possible to upgrade older EasyFold racks with the new tie bars with straps.Thule EasyFold 3 | Thule | United Kingdom
Interesting update. I have the EasyFold 2 and while I drove a couple of trips with 3 carbon bikes over 1500 kms I would still be interested if those arms are backwards compatible. The max weight that I've caried with it was one e bike 24 kgs, another 21.5 kgs and an enduro bike of 16 kgs. No issues at all but had to be a bit careful not to break it when folded as the overhanging weight was quite high
On a pals thule rack we clamp our two Cube Stereo Hybrids on body of the rear shocks. Its a perfectly round section for the jaw to hold and its plenty strong enough to take the clamping force.
I wouldn't do that if I care for the bike. If the distance is short and roads are smooth maybe, but otherwise a pothole is enough to put a massive tension on the shock mounts and there woould be high chances they will crack
I did think of that but somehow didn’t fancy it like I’m not 100% convinced about clamping the dropper post in the work clamp.
Regarding the forces ... I don't buy it that it would put undue stress on the shock mounts.
The wheels are ratcheted down hard onto the rack and this is what holds up the bike, and the clamp doesn't need to do anything more than stop the bike from falling over. Hitting a pot hole driving along will see mainly vertical forces which would be absorbed considerably by the tyres of the vehicle, the suspension of the vehicle, the the flex of the rack on the mount before those forces reach the rack clamp around the shock. The way the clamp is will more likely flex with that vertical movement rather than try to stop it.
That leaves horizontal forces through the clamp. Acceleration / deceleration of the car I reckon would put far less force into the shock and pivots than say stamping on the pedals under power with the bike leaned over, hammering down rocky / rooted trails, drop offs, jumps, etc etc.
the pivots are designed to take all the loading and forces of the bike being ridden at speed ... I just cant see how being held in a bike rack would beat that force load beyond its design spec.
I have a Buzzrack Scorpion I think - the XL built for ebikes - and it's been faultless. Really well made.
The clamps have never come undone - they work in a way that once you remove the key the clamp cannot undo.
As Fisha says above - the clamp is really just to keep the bike upright. The clamp doesn't even need to be done up that tight, it's just got to hold the bike. The bike is mainly secured by the straps at the bottom.
Absolutely not worried about clamping an ebike by the toptube.
I've got an eScorpion too - the single version. I have an Altera Strada DL for taking multiple bikes, but bought the Scorpion for going out on my own as it's much easier to lift onto the car. It's also a lot better made than the Altera one.
I actually bought the bits and made up a second arm for it - so that I can grip my top tube in 2 places. I used to secure bungees round the bike, but with the second arm, I don't need to. I lock them both, so there's no chance of the bike falling off. The thing I really like about the eScorpion is the 2 clamps for the front wheel - which stops any attempt at it trying to 'steer' when on the rack. It means the bars are fixed solid. A really well thought out unit, folds down neat, and significantly cheaper than most other brands. Mine is over 4 years old now and still A1.
I’ve just bought the same rack, although haven’t used it yet. Did you buy a whole arm unit or just the bits? Where from?
I bought it as bits from www.roofbox.co.uk
They have an exploded diagram with part numbers on it. Make sure you ask for the same lock code as the one already on your rack when ordering, so that you just need 1 key for all.
