Levo Gen 2 Specialized turbo levo 2020 xl chain length
Bwian
Danmark
Hey hey i cant find the info anywhere so i Will try here. What is the correct chain length for med Levo turbo 2020 xl, i accidently threw put my old chain and I bought one to short. 🤪bike is stock
Looking forward to your answer.
Brian
Brian
Er, take your old one and put it against the new one and measure. You LBS I’m sure will assist. But make sure you are using a decent chain suitable for a e-bike
Thanks for reply but I dont have the old one anymore.
Opps, get a SRAM chain as likely came with bike and watch one of the many YouTube videos on putting on a new chain. You might want to get a couple of quick release links to make the job easier. Oh save the short piece you remove from the new chain and take it with you on rides in case you damage a section. Take a tool to shorten the chain on rides in case you damage the derailleur. The most common cause of excessive chain wear on a e-bike is too high a gear, this doesn’t just wear the chain but the cassette and chain ring.
Remove what looks like lubricant on a new chain, it isn’t lube but corrosion inhibitor. I use a candle wax hot dip on my chains that I mix with PTFE powder Messy to put on but lasts forever and the chain stays sparkling clean. It does not attract dirt etc and it doesn’t go black like oil based lubes. It what pro cyclists use
Good luck, you sound like a novice but remember there is no such thing as a stupid question
B
ps. My English both spelling and grammar is crap, a little surprising since i’m English, been living in America too long😂
    672K
