Levo Gen 2 New crank bolt needed (Praxis)
Grannyjones
England
I rounded the Praxis 8mm crank bolt on my 2020 Levo. I need to get a new one. Does anyone know if it is possible to find one that is compatible ?
Thanks for that
Unfortunately due to price of ordering a pair, including shipping from the EU, it is not far off the price of ordering a new set of cranks, so I've now done that instead
If it‘s the same screw as the praxxis crank for fazua, the e13 helix crank screws will fit. My lbs used these when i had the same issue with my praxxis cranks as ypu.
I made a bit of a mistake. I thought ordering new cranks would not cost that much more, but it turns out they were only selling a single crank arm and not a pair.
So it's back to ordering new bolts again: Does anyone know how to get the crank bolts off ? It seems like one side requires an allen wrench that is far bigger than any that I've got, and the other side requires some sort of specialist tool ?
Both sides have the same self-extracting screw as I gave you the link, but you only need 8mm allen key for the inner screw, unscrew it (you may need to use a bit more force) and it will pull the crank right off ... When you will install it back the bolt says you should torque it down to 50Nm but this is too much and you may damage the threads, I find 40Nm more than enough for this screw ...
    Join 43,208
