Excuse my ignorance.
stuhawk
Midlands
Bike maintenance and understanding of components isn’t a strong point of mine.
Just got a 2022 Rise M10 and looking to change up to 4 pot brakes. Do I need to just swap out the calipers or does it need a whole brake set?
Thanks folks.
Thanks folks.
What make and model of brake levers does it have because they might work fine with 4 piston calipers?
220mm rotor for the front wheel, 203mm for the rear. (For my type of riding). New calliper spacers may be required to position the calliper brake pads correctly to the rotor(s).
The additional weight of an eMTB may require stronger brakes. Especially when everything is added up. Trail conditions, body weight, backpack, speed, weather etc.
It’s fun to go fast …but nice to slow down too.
Thanks folks.
What make and model calipers (2 piston?) are currently on the bike? Front and rear?
Then buy a pair of MT520 or M6120 calipers (same caliper, whichever is cheapest) should bolt straight in and will transform your brakes (usually pre-bled but you might need to do a top bleed). After that as @steve_sordy says go to larger rotors.
And no need for different levers?
Question: If im just changing the calipers what else do i need to do to complete the swap.
Apart from basic tools, nothing else as long as:
1. You are careful to avoid leaking brake fluid when changing the calipers.
2. You should be able to fasten the new calipers using the existing olives.
3. The calipers are pre-bled (which they normally are).
Probably worth doing a "top bleed" using the below kit (or similar) with some genuine Shimano brake fluid. It's really easy but be careful not to lose the tiny rubber O ring on the brake lever top screw and don't overtighten the screw because the threads can strip (don't ask me how I know 😉)
Shimano Workshop TL-BR003
    673K
