I doubt it's cast iron and looking at it I'd guess that's the typical weight for a machined Al of that size.
Someone put a magnet on it to find out.
It is heavy isn’t it!
Could only keep one....which?By the way, loving this bikes handling. The suspension performance is incredible. As is the handling. It handles so much lighter than the weight suggests.
The rear suspension is so supple, ultra reactive and actually feels pretty playful, which surprised me a bit.
I’m running it as a mullet bike, I reckon the weight reduction out the back with the smaller rear wheel and tyre, no mech / cassette massively influence how the rear end performs.
Hitting enduro trails on the bike is so good. Ultra quiet, very good chassis and incredible suspension.
The motor noise still bothers me on gears 1-4. And it’s a bit clunky elsewhere. I’m getting used to it, but have a wish list for a V2 Pinion already!
How is the Ohlins suspension vs the Intend that you had on it?By the way, loving this bikes handling. The suspension performance is incredible. As is the handling. It handles so much lighter than the weight suggests.
I did some digging into this. It looks like this tensioner is second iteration of the one used on the GT1 EBOXX bikes. The original version looks like it had a CNC alloy swingarm and an external mechanism to adjust spring tension.It is heavy isn’t it!
Wonder why they chose this material? I can only assume it’s for strength/ durability vs aluminium - it’s exposed under the bottom bracket so will no doubt be at risk of impacts.
A lot to unpack here:My bet is that this tensioner is provided by pinion, same as the crank?
Maybe Nicolai could have machined an AL one but as we mentioned it, casing this part on a jump and it could really destroyed the bike with a light piece.
As for v2 to me:
- tob tube integration or low profile controler
- noise
- tensioner more integrated. We could have a higher fixation of the pulley that does not go lower than BB
- wonder about an inverted installation of the tensioner or a high pivot / could generate drag so I do not know
- slim battery, down tube is very big
Out of interest when did you place your order?My frame is due any day now. Will report range.
No, none of that stuff. Just the frame, no shock, but an extra batteryDid you order it with the explorer kit/racks etc.?
August 22. First inquiry was in July with a quoted delivery week of (german) calendar week 40, when. placed the order delivery was estimated for week 43, which was later postponed to week 45 and I collected the frame yesterday (week 46). Building the bike was simple and I just returned from our local trails where I applied some November dirt on the shiny new bike. Can't say much right now because the trails were in a super gooey state, but the bike felt familiar right away... next Saturday we're having a long ride and weather is supposed to be better by then, so we'll see...
The motor is not quiet, I think it's something I can get used to though. When pointed downhill, the bike is by far the quietest bike I ever had. Impressive!
Edit; I did a last minute swap from Fox DHX to EXT e-Storia @ 205x65, so 166mm rear travel. The shock is supported by Nicolai and you can get it with a frame or complete bike.
Yes. When I collected the frame, I was told that customers reported belt squeaking with their "antiskip" sprocket, which led them to reverting to the standard one, with a snubber. I personally prefer the look of the silver one anyways and don't mind the snubber. Have changed the front sprocket to a silver one without bash guard in the mean time, too. Both sprockets are stainless steel though, not alloy.Has Nicolai bailed on the their proprietary rear sprocket? I see a snubber hugging the belt and full alloy rear sprocket on this bike.
She’s a beauty! How’s that Push suspension ride?
really amazingShe’s a beauty! How’s that Push suspension ride?
A few more months at least before I get anywhere close to being able to try what you're looking for... but for starters, here's pics:Sorry to hear about being laid up after the crash. Is it possible to get a close-up picture of the snubber and how its mounted?
When you get back into the fray of riding, I was wondering if you (or anyone else with snubber-configured version) run an experiment:
The reason I'm requesting this is that the ratio of the motor requires a pretty larger rear sprocket at 32T - that seems like enough teeth to prevent belt slippage under tension. When using other internal gear transmissions like the Rohloff, the ratio is such that the rear sprocket needs to be quite small (like 20T). In this situation a snubber is essential as there is simply not enough teeth for the belt to cling to. But 32T and at a larger diameter MOA is larger, I think it just might work without one. Of course, belt alignment would need to be true and use Gates CDX belt.
- Remove the snubber before your ride and take it with you.
- Ride the bike in various conditions (uphill and down) and see if the belt skips. If it skips a lot then put the snubber back on during the ride.
- If skips infrequently, then try turning up the spring tension on the belt tensioner and see if it stops skipping. Of course there is a sweet spot of belt tension for proper performance, but perhaps running a bit more taught might help.
Thanks for snapshots. Since the snubber is just a bushing rather than an actual roller, It leads me to think that belt skipping is rare with this model. I don't think that would fly with something like a Rohloff, where the gear ratio of the IGH requires very small rear sprockets (18-22T).A few more months at least before I get anywhere close to being able to try what you're looking for... but for starters, here's pics:
View attachment 153012View attachment 153013
There is a tiny gap between belt and snubber, less than a millimeter I'd say. I can shove a sheet of paper between belt and snubber, but not much more. The snubber has some scratches already and I'd guess it is something that needs to be replaced frequently. However I too feel like the snubber might not even be necessary.
Hi Steamboy here my 2 cent . I Own an Saturn 15 mgu XL and an Nicolai Eboxx G1 Xl from 2021Hello,
Nicolai Saturn is a quite facinating bike, and as I want to change mine, I am looking for information from first hand real user.
- I was wandering if, on flat surface, above 25km/h, it is similar to the behaviour of the bosch system, even with the included gearbox ?
- Is the 720 battery capacity is similar to bosch system (the only I know) in range, and if it exist a range extender vs the 960 kW version ?
- 27 kg is not on the light side, even for an aluminum frame, how does it feel in the day to day operation ?
Thanks for any feedback,
Regards
