Sounds more like a faulty bike based on his first post - mainly riding motor off as it's easier ??
Maybe it’s set in trainer mode not assist mode?
You mean OFF, Operator Full Force?Maybe it’s set in trainer mode not assist mode?
Insufficient research resulting in wrong bike,
It takes time to adjust your riding behavior. Its about synching your pedaling cadence, gear selection and PAS level.Just purchased a Whyte E160S with a Bosch motor, and wanted to understand how this works as it would seem that I’m constantly working against the motor rather than assisting me. Everything looks like it’s setup, but I’m riding the bike more without the motor on, which defeats the object. Any ideas or is this how it is with the 25kmh restriction?
They will be watching the promo adverts the experts can do everything on there Like that toy you got at Xmas as a bairn nothing like the adverts.Some people don't know how an emtb is supposed to ride.
I was talking to someone who was demo'ing a bike at a shop recently. They were disappointed it didn't do power wheelies pedalling out of corners.
@Andyd1966
Are you still here?
It seemed a good spec bike for the money, and was Similar to my old analogue bike. I don’t think I realised it was restricted that much. I mainly ride a mixture of single tracks with lots of climbs and few downhills. Funny enough when I first rode it the sensor was actually anywhere near the magnet on the hub, so the assistance did not work at all. I have now rectified that. I guess I assumed the pedal assist would be more obvious, as I have had lots of people pass me on hills in the past on EMTB’sOut if curiosity, why did you pick that particular bike? Did you know about the motor assist cut off before you bought the bike? Do you use the bike more for commuting than for XC or DH riding?
I think I have to reset my expectations, and probably my cadence! Any pointers in setting up the motor in each of the setups would be helpful. Thanks all for your support so far."it would seem that I’m constantly working against the motor"
Constantly, really ? Surely you're not working against it when turned on and below the 15.5mph limit ?
The motor turns off above this speed and the weight of the large frame, motor, battery + motor friction adds up to mega heavy pedalling. There is no time when you should be on an EMTB with the motor purposely turned off unless you need to build massive thighs !
Use it in standard power setting on the road and on the trails, you'll get many hours of fun and still get a workout.
If you want to go fast on the road, get a road bike (non electric) or buy a Chinese unrestricted 500 - 750watt hub motor bike shaped object from an importer.(aka a throttle bike)
When on trails or hilly roads - always select the correct gear to assist the motor (yes, you help it, it helps you)
Go into a lower gear, increase your leg turnover rate and your motor speed too - just as you would in a car rather than labouring the engine. (so many autos, elec. & DSG cars on the road now that this analogy is really aging me !)
Good luck, happy trails & safe fun Andy 1966 - Frank from 1972 !
If there's no fault with the bike you should be benefitting as much as those other riders on the climbs - just be sure to have it set at std. or max power - running it on eco. on an uphill course is a waste of time.It seemed a good spec bike for the money, and was Similar to my old analogue bike. I don’t think I realised it was restricted that much. I mainly ride a mixture of single tracks with lots of climbs and few downhills. Funny enough when I first rode it the sensor was actually anywhere near the magnet on the hub, so the assistance did not work at all. I have now rectified that. I guess I assumed the pedal assist would be more obvious, as I have had lots of people pass me on hills in the past on EMTB’s
Can you dial back the Nm, and have the PAS come on slower so the bike isnt racing to to its limit?It seemed a good spec bike for the money, and was Similar to my old analogue bike. I don’t think I realised it was restricted that much. I mainly ride a mixture of single tracks with lots of climbs and few downhills. Funny enough when I first rode it the sensor was actually anywhere near the magnet on the hub, so the assistance did not work at all. I have now rectified that. I guess I assumed the pedal assist would be more obvious, as I have had lots of people pass me on hills in the past on EMTB’s
What kind of sensor/magnet is it? I though it is either on the brake disc or rim.It seemed a good spec bike for the money, and was Similar to my old analogue bike. I don’t think I realised it was restricted that much. I mainly ride a mixture of single tracks with lots of climbs and few downhills. Funny enough when I first rode it the sensor was actually anywhere near the magnet on the hub, so the assistance did not work at all. I have now rectified that. I guess I assumed the pedal assist would be more obvious, as I have had lots of people pass me on hills in the past on EMTB’s
It's a good bike and very good spec for the costIt seemed a good spec bike for the money
It was in budget and most of the reviews were positive., I guess I just need to get used to how it works. Unfortunately I have some road riding to get into the countryside.
By all accounts they're decent bikes.It was in budget and most of the reviews were positive., I guess I just need to get used to how it works. Unfortunately I have some road riding to get into the countryside.
It's certainly a really easy way to answer the question. I'm at home most days and can get to the trails within 30s from my house, so we could have an answer within 5 mins easily.I'd recommend taking @Weeksy up on their generous offer - I suspect we can only help so much remotely.
Very good to hear you've found the cause and the solution. Many thanks also for letting us know - it may help someone else in the future, and some of us (like meFinally found the issue. The sensor and the magnet were not in one at all, so the motor was pulsing. I’m guessing it was installed wrong. Thanks for all your tips and suggestions. Lots to learn!
