Levo Gen 3 my turbo levo comp went for service - was told it showed up as an 2022 model?
Razorx
Sweden
I left my bike for service since the freehub broke. The LBS asked me when i bought it and i said 2024.. in january.
He said.... Thats weird because our program said it was a 2022 year model?
It thought that was weird... It has the golden harvest color so it should be atleast a 2023 year model but im 100% sure that when i bought the bike the dealer (who is not the same who i brought it to now) said i was a 2024 year model.
Has anyone had this issue? That the bike shows up as a diffrent year model in on serial number?!
The label located under the upper frame tube should tell you the manufactured date.
It may just be that the frame is 2022, but the rest of the bike is as described.
Were there any design changes to the frames 22 vs 24?
You are well advised to get the story (in writing for preference) for when it comes time to sell your bike. The dealer should get the full story from Speccy for you.
Mine was also advertised as 2023 model year but the frame sticker says it was produced 07/11/2022. With the new App Specialized also removed the option to see the motor version. Anybody know how to see which motor version it is through another app? Blevo maybe?
I think the 2022 base models (idk if alu and carbon) had a 500 wh battery while the 2023 models have the 700 Wh batteries plus the aluminium models got the mission control tcu but not the carbon base model.
Its a bit uncool from specialized to not better communicate which model years have which motor revision/update because this kinda looks like they tried to cheap out on that and try to get away with selling not updated motors to customers that don't have the 4 year warranty extension.
The prodution date doesn't tell you the year model, only when it¨s made. From colours and specs you'll see the difference in model year and if there isn't any, then it doesn't matter. All Turbo Levos use same motor from 2021, even the last Gen2, only the charging port designed changed on Gen3. Batteries are also same.
There are at least two versions of the 2.2 motor:
  • Drive S Mag, horizontal, E06855-100
  • Drive S Mag, horizontal, E06855-200
the first one is an older revision and then there are the software updates that should change to motor characteristic to make the motor stress the belt less. There might also be small hardware changes between these versions in terms of longetivety, noise reduction and water ingress.
With the new app specialized removed the ability to see which version of the motor the bike has. The problem is that specialized and brose tried to make running changes coupled with extended warranty for older models and the running changes proved to make the motors more reliable over the last years and people with the generations of the really bad motors got a 4 year warranty but its a bit unclear if you buy a gen 3 model of a levo if you have to most reliable version or a version that will hold up for a few thousand miles and then snap the belt when you're out of the 2 year warranty period.
Ok good information!
The serial number i have is E01680-200220 !?! What does that mean... i have an older yeneration motor?!
And can someone tell me how to decipher this code to what model year: WSBC00111****T (dont know how much i can show)
Unfortunately BLEvo dosn't show the motornumber on Gen3. I'm searching for a tool that does it too ...
I contacted specialized who have me my motornumber.
I would like someone to tell me who to can decipher this code to what model year: WSBC00111****T.
Apparently, even after 2021 that’s has been a number of running upgrades to the motor. Not sure if this it true or just marketing / pr. my Levo has a build date of Feb 2024 so I would hoped to have one of the newer motors.
Apparently there is also this version:
E01680-200 has a completely new belt. Polymer plastic with Kevlar fibers from the supplier Dayco.
    677K
