Help needed: M510 FC2.0 not switching on
I tried disconnecting the ribbon from the bms to no avail. But perhaps I could have waited longer than a couple of minutes. I ignore whether the bms has capacitors that can hold current for a while. I will try again for longer, perhaps a couple of hours. My bms is sort of branded, but its laser engraved, making it really hard to read (apart from being most of it in Chinese). I had to take a picture at an angle to be able to read something. It also has a QR code, but my phone could not pick it no matter how hard I tried. I could verify that it's a 13s4p 48v 35a. I will take a look at it again to confirm whether it's a common or split port, although I am pretty sure is the first. Even if it's not the root cause of my problem, I am tempted to replace it for a Canbus/bluetooth enabled one, since they are quite affordable. Anyway, I am waiting on Chilli to provide diagnosis. One other thing I could verify is that the cells where actual Samsung 35E.
The Dengfu E10 does not use Bafang's batteries either
Hi Karambal
I've read your post and wondered if you managed to resolve your power issue as you didn't post a conclusion after changing so many parts of the system.
The reason I ask is I have a new Dengfu E10 with a M560 motor and C245 V3 display unit that's only been ridden a handful of times and developed a similar problem to yours. Basically I was out for a ride and stopped 15mins for snack whereby the system went into standby. However when I tried to power on the display the bike would not power on and never has again since.
I don't have a Besst Tool but have carried out some rudimentary diagnostics.
The first thing I did was to fully charge the battery even though I suspected it had at least 80% charge but was unable to confirm this at the 6 pin battery output connector as I don't know which pins are shorted out by the on/off switch in order for the battery to provide an output voltage that I could measure. After charging the battery I remembered that the battery voltage could be read at the motor power input XT60 connector, which measured 54v. I was also able to rule out a faulty on/off switch at the same time as I could switch the connector voltage via the on/off switch.
Unfortunately I was unable to measure whether the motor was passing current up to the display unit as the pins on the display input connector (which come from the motor) are very small and I didn't have any probes small enough to push into the connector. I could've purchased an extension cable and cut off one end in order to make a breakout cable but being as the motor system is still under warranty I didn't want to spend anymore money as I suspect the issue maybe a faulty display unit so I decided to contact Dengfu with the issue.
They've been very good and have passed the issue over to Bafang who have agreed to send me out a new display unit which I'm currently waiting for (I'm hoping for not much longer).
Just out curiosity do you or anyone else who maybe reading this know what the 6 pins at the battery output are on the Dengfu CAN-B 48v 17.5ah battery? I would like to reduce the voltage to storage level asap as it's been sitting at a 100% for almost a month and I'm concerned the cells maybe damaged as a result if the voltage isn't reduced to 70-80% soon.
Any help would be greatly appreciated.
Hi EMTB Ryder!
look my post Dengfu E10 New CAN Battery 6 pin
but I think it is no problem for 100% wait, not SO problems...
...if you check 54v on motor connector you power switch on frame works, next you should reconnect and double check how you connect main wire to motor (from display to motor) on my bike after assembly this connector disconnect suddenly
and reconnect buttons wire to display
as I know startup: frame power button - 54v on motor connector - motor send power to display (5v may be) - power button on display - display wake motor by 1 wire (P+ on image) - motor board wake - display send can massages to configure motor - system started
not my schematic: get it on Bafang_M500_M600/Hardware/Cables M500_M600/Bafang_M500_M600_Display_Cable.png at main · OpenSourceEBike/Bafang_M500_M600
