Levo Gen 3 What size Ohlins TTX coild shock will fit Specialized Turbo Levo
DJEMTB
North East
I have a 2023 Specialized Turbo Levo Expert with a Fox Float X2 rear shock. It has been leaking air, and I want to upgrade to a coil spring. I've used the Ohlins TTX on other bikes and wanted to look at upgrading my Levo with the Ohlins TTX.
I went to Ohlins site and it says I need the TTXM.2 210x55 - is this the correct shock specs for the Gen 3 Turbo Levo? I wasn't 100% sure I was looking it up right. just want to make sure.
Yeah I run a TTX on my levo , great shock once you get the correct spring weight dialed in 👌👌
You're bike looks awesome. I have a 2023 Expert and one of the best upgrades I did was the Hope Ebike cranks. I went from the 160mm praxis to the 155mm Hopes and it made a HUGE difference. I was surprised that 5mm gave me that much more clearance.
It looks like you have done the same thing with your cranks and Hopes. Did you go shorter as well?
Also, I wanted to ask about your Shock. Does it add much more weight? What is it like pedaling? What spring rate did you get?
I am a bigger rider coming in at about 140LBS with all my gear. When I looked it up on Ohlins spring calculator it said my weight exceeds the limit. I can't imagine that is true. Do you know of a better spring rate chart?
I just did a quick search for availability and price yesterday and I was seeing cost of about $850 for the TTX, is that about what you paid?
"I am a bigger rider coming in at about 140LBS with all my gear." ??????????????????
    673K
