Karamba!
Hi,
2 days ago I was leaving for a ride. When I turned on the bike through the remote (DCP245 v2) nothing happened. Tried several times but nothing. Less than a minute or so later I tried again, and it turned on fine. Went on with my ride, everything was working fine. I rode for a couple of hours and took a rest. The motor auto shut-off kicked in and I could not switch it on again. Hours later, I could switch it on again and noticed that I could not switch it off through the remote. Since then I´ve been unable to switch it on again.
I connected it up to the computer through Besst Tool, and the screen turns on normally, but it shows 0% battery, and the controller info could not be read. At a given point, out of the blue, the battery level showed up, and I could read the controller info just fine. . I took the tool off thinking that the motor will turn on but it didn´t. Hooked everything up again and the battery showed at 0% again. PAS changed normally through the remote
I have checked that the battery is delivering power normally and I checked the harness for continuity, and all was fine. I have also triple checked that connectors were fully on on both ends.
This is what the display shows when connected to the PC:
I am ready to open up the motor since it could use a maintenance, but I am not sure what I can do to troubleshoot the controller. I also wonder if the remote could be the issue, but I´m more inclined to think it´s the controller due to the display showing 0% battery in circumstances that it is fully charged and there´s continuity in the harness.
Any advice or tips are welcome.
