Lupine C14 cable routing
superchiwawa
Beer land
Anyone fitted a Lupine C14 real light to their rail? How did you route the wiring?
Neatest solution would be drilling a small hole In the seat post as lupine have done on their demo model, but don’t fancy giving up my lifetime frame warranty.
Was thinking of modifying the charging porting and routing through there somehow, bar behind the swing arm and through the bash gaurs (cable pinch risk) but curious as to what others have come up with.
Care to share ? :)
Looking for the same info - can anyone share this?
you can route the cable straight down the tube, use the included cable guide (the glue is very strong), then route the cable behind the swing arm. it is a tight fit, but it will fit. I placed an extra shrink tube for more protection. Then route the cable into the motor. This is the best solution to route the cable without drilling a hole for the cable (I didn't want to do that). I have run the light for about 5000km, works great. and the light is really good. It also blends in really good on the seat post.
    674K
