Hi, I got 3 inoperative Giant Energypak batteries. In all of them, 2 LEDs charge indicators are lighting.
But when I plug the charger nothings happen (no matter if battery is in bike or not), and LED in charging is lighting red, when it should be flashing green.
I checked the voltage on batteries pins and from left:
battery 1 500 Wh
pin 1: -
pin 2: 1,5v
pin 3: 0v
pin 4: 0v
pin 5: 35v
pin 6: 0v
When I plug this battery to bike everything looks ok, I can connect bike with application, "checking system" show that battery is ok and motor works. But when I plug charger to bike it turn off, and after that it won't turn on.
It "restarting" when i swap the battery to working one.
battery 2 625 Wh
pin 1: -
pin 2: 1,5v
pin 3: 0v
pin 4: 0v
pin 5: 35v
pin 6: 0v
With this battery in the bike when I try turn bike on, controller flash LEDs ones and nothings happen. When I try second time nothings happen. Same as before this restarts after swapping battery.
battery 3 625 Wh
pin 1: -
pin 2: 1,5v
pin 3: 2.5v
pin 4: 2.5v
pin 5: 35v
pin 6: 0v
With this battery in the bike, totally nothing happen.
The only thing I found on forum is that, when voltage is seen on pin 5, battery is in "ride mode" and that's why it won't charge.
But I couldn't find any info about what caused this issue and if there is any solution.
Any ideas? Maybe someone meet similar problem.
battery 1 500 Wh
pin 1: -
pin 2: 1,5v
pin 3: 0v
pin 4: 0v
pin 5: 35v
pin 6: 0v
battery 2 625 Wh
pin 1: -
pin 2: 1,5v
pin 3: 0v
pin 4: 0v
pin 5: 35v
pin 6: 0v
battery 3 625 Wh
pin 1: -
pin 2: 1,5v
pin 3: 2.5v
pin 4: 2.5v
pin 5: 35v
pin 6: 0v
