Levo Gen 3 Are these the right cranks for a gen3 Levo?
DirkWisely
California
And does it matter what my front chainring is for crank compatibility? I'm installing a SRAM GX T-Type Eagle Transmission AXS Groupset soon, and I'm not sure if that's a factor for crank arms.
Would appreciate any help!
Yes. You'll want the Specialzed Offset version from Hope — it takes into account an offset that shifts the cranks approximately 4mm to to align with your frame centerline. Regarding your chainring (and spider), they are mounted independent of the cranks, so there should be no issue with Transmission compatibility.
Thanks I appreciate it. I thought I had it figured out, but there's so much to know I thought it'd be worth confirming.
Yes. You'll want the Specialzed Offset version from Hope — it takes into account an offset that shifts the cranks approximately 4mm to to align with your frame centerline. Regarding your chainring (and spider), they are mounted independent of the cranks, so there should be no issue with Transmission compatibility.View attachment 146262
I have the "older" SRAM Eagle 34T steel chainring (104mm | X-SYNC 2).
I just wanted to confirm: can I simply remove the stock Praxis cranks on my Gen 3 Levo and install the Hope e-Bike Specialized offset without needing any additional adapters, or parts?
Thank you in advance.
