• Warning!!
    UK Pedelec Law
    Worldwide Laws
Levociraptor, Turbo Levo motor failure and warranty void.
Yep de restriction is the only way on the road or it's abysmal
I'm happy to do 25mph on the road. Just using normal MTB gears but in the top gear with the motor propelling me along.
Overtaking roadies and almost keeping up with cars, so very few have to overtake me on most road sections.
For this to go back to 15mph with the motor constantly cutting in and out would be a very sad day indeed.
I noticed the date of the original post was Jan 2024.
I suffered a motor failure since then, in April 2024. Removed the Levociraptor, reset the de restriction to 0, and the bike shop still replaced the motor under warranty.
So I'm wondering how the person who created the original post got detected yet I didn't despite mine being more recent and having the firmware "at least" as up to date ?
One possibility is that the shop did indeed detect the use of the Levociraptor but ignored it and replaced the motor.
There are some things you can do to be able to maintain more speed on both tarmac and flat singletrack. There is no speed limiter, just a limit to motor assist. When ride in the forests it is all steep downhill or riding back up to trailhead so not an issue. When we ride cross country we cannot avoid a few road sections. What slows you down after the motor cuts out on those sections can be alleviated by using lighter weight and faster rolling tyres....tyres that still provide enough grip on off road terrain...at least in summer conditions. Also run with higher pressures. Then get used to using lower gears/ higher cadence before the cut off speed. Be aware that also on the open road speeds much more than 15mph start produce quite a bit of wind resistance.....and our bikes and our usual baggy riding gear have a lot of wind resistance!! Even wide knobbly tires increase that...which you soon discover in any sort of crosswind!
My bike is 26kg with full enduro geo etc....I can maintain 17/18 mph on open road as long as there is no strong headwind.
If you change the frame to a road bike , tyres to road ones , wear Lycra you might get up to 19 😂
Exactly! Horses for courses. Tarmac is boring at any speed.......and pretty dangerous if a main road......fortunately for me if I have to do a tarmac section it is just country lane and pretty short.
I do so many different routes and rides, that some rides have large amounts of riding on main roads full of traffic, and some rides have no road at all. Plus everything inbetween.
On quiet roads I often actually get my entertainment from pulling wheelies. Another problem a 15mph restriction would cause is if I'm in the middle of a wheelie and hit the 15mph limit it would almost certainly end the wheelie.
De restricted e bikes are great at getting road sections out of the way with quickly. Plus it can be quite fun sometimes doing 25mph on the roads, but some roads are no fun no matter what. At least it gets it out of the way with quicker.
If I never rode on the road at all I probably would not be bothered by the 15mph limit very often
    672K
