Will this charge my battery?
Dave_B
Newquay
I’ve just ordered this.
Being a numpty, im assuming that because it is a 1000wh capacity it will charge a 700wh battery?
@VWsurfbum
Yes, I would think it should be able to charge your 700wh battery full once before you need to recharge the power station.
The important factor is how much power your charger draws, and how much power the Portable Power Station can put out.
It says it can output 1500 Watts. So as long as your charger doesn't draw more than about 1200 Watts. You should be fine.
It’s a Specialized Levo gen 3 charger. I don’t know what it draws.
Spesh chargers draw about 180w. That should do a full charge of a 700 battery from flat depending on how efficient the inverter is.
For example my 1500 unit will have 30% left after a full charge.
It charged up my 700wh battery from
about 20% charge. When done, the jackery still has 20% remaining. So all good. I got a free 80w solar panel when I ordered it, so it will be more than fine for a two ride trip.
Excellent!
If you get the Jackery on the charger a day of Arizona sun in the USA will fully charge the unit..
I'm a snowbird so northern Wisconsin...not so much. 2 days probably.
Are you British?
Bill
