Levo Gen 3 Hope rotors
Hicksy 92
Stonesfield Oxfordshire
Hi all has any one fitted hope rotors to there 2022 Levos , any issues with fitting or is it a straight forward swap , obviously i‘ve got the standard factory fitted sram code r’s atm
thanks
I have the Hope HD rotors, 200mm front and rear with my code RSCs. I had to reset the pistons to get them in there and recenter the callipers but after that it was good to go. The HDs are a bit thicker than the floating rotors though so those may be easier to fit.
I am hoping that these rotors will work with my SRAM DB8 also!
I thought it was good to go, that lasted about a week or so of riding. I ended up having all kinds of issues with the Codes with these rotors. I got tired of dealing with it and upgraded to Hope T4 V4s, the codes are in my parts bin🤣😂
Do you know if the dimensions of the calipers for the Codes are the same as the DB8? As far as the rubbing.
No idea, the calipers do look like the same though. I kept having to reset the pistons, I’d get a few rides in before the rubbing issues would start again. I just got tired of dealing with it and bought the new brakes.
Edit: I’m using the Hope HD rotors that are 2.3mm thick, if you’re using the standard Hope rotors you probably won’t have any issues.
