Hope Floating Rotors and SRAM DB8
I believe you'll need 203's with the DB8's, correct? They seem to be out from that location, but surely they're available elsewhere?
I am currently on 220/200 with my Strive ON. They both show in-stock, I am just trying to make sure they will fit.
I also read something that said Hope redesigned the rotors, and the rivets are now more compliant with other calipers like the DB8.
I would advise getting in touch with Hope UK or seeing as you're in the USA, maybe discuss your requirements with Jenson USA, they have hope floating rotors on offer for $55 which is a significant saving on the eBay options.
I did write to Hope and they were no help at all. All they did was suggest that I buy their brakes.
I did a test fit, and it looks like they will work. The area where the bolts are is slightly recessed, and there looks to be enough clearance.
