Rail (625Wh) trek rail 5 chain ring
ant
northampton
hello i’ve got a trek rail 5 2023 and im after a bigger chainring as i dont use the low gears anyway and do a lot of high speed,
i know theres not much room there but i read somewhere that you can get a offset one.
thank you
thank you
The Rail comes with a 34t chainring, from what I remember with mine, there's very little clearance to fit a larger chainring and off-setting to allow fitment would put the chainline right off.
yes it does come with a 34 t chain ring as standard,i read somewhere on here that you can fit a larger one if you space things out and don’t use the big gears
    675K
