Other Removing Seat Post from 2018 (Gen1) Levo
super easy.
step 1 : detach the command from the bar,
step 2 : unscrew seatpost and pull it gently out of the seat tube (while you pull the post, you can push the hose in the frame) until you see the hose end coming out of the seat tube.
step 3 detach the cable from the post and place the post in a safe place.
Step 4 detach or cut cable from command and pull cable out of the hose, from the post side.
step 5 remove the little metal end on the hose near the post and pull the hose out of the frame from the command side. Done. there could be faster way but this one works fine and takes 2 min.
There may also be a clamp or sharp kink hidden inside the frame that could prevent easy removal …depends on frame type.
Your gonna love the AXS Reverb dropper.
Ps; some people can remove the cable in less than 2 minutes if you don’t stop to eat a sandwich. 😜
Yeah, this is what I'm worried about.
I don't want to remove the motor...
super easy.
    670K
