DaveNewing
Hi everyone. My damper has blown in my 2020 pike ultimate fork. I have a spare rc damper unit from a 2020 lyrik and wondered if it would fit and work whilst the pike damper is away being repaired.
Thanks for the advice. The parts catalogue only seems to give part numbers for damper unit upgrades, and not the original damper units. My lyrik damper is from a select fork and therefore the catalogue doesn't give it a part number.Check the Rockshox spare parts catalogue to see if it will fit.
https://www.sram.com/globalassets/d...catalog/2023-rockshox-spare-parts-catalog.pdf
Page 3 will give you the page number of your Lyric damper. Then go to the Pike section to see if the same part number is a listed spare for a Pike fork. Good luck!
Edit: I had the link for this catalogue from when I did an upgrade a few years ago. I have just noticed this one is 2023. Check the year numbers of your Lyrik and Pike forks, just in case the part numbers have changed.
Thanks for the info. The air shafts are cross compatable between lyrik and pike, but I don't know if the damper units are the same.
I thought the only thread pitch change on current stuff was the awful 35?I think the threads are different.
I'm not sure, hence the "think". Pike and Lyric chassis certainly used to be different.I thought the only thread pitch change on current stuff was the awful 35?
Yeah me neither. I know for sure the Yari & Lyrik are the same chassis & have turned a couple of Yaris into Lyriks by swapping dampers for the cheap win & I 'm fairly sure the Pike is a different chassis from those two. I understood the 35 was built to be stand alone with different diameters & thread pitches etc so as not to be upgradeable which has been suggested a few times was a cynical move by RS. Don't like the fork? Have to buy a new one etc.I'm not sure, hence the "think". Pike and Lyric chassis certainly used to be different.
Bummer!Turns out a lyrik damper unit will fit into a pike, but it's about 20mm longer than a pike damper. I'm not going to tempt fate in case the extra 20mm bottoms out at extreme travel. I'll have to send the fork off to tf tuned for a service/repair.
I took my fork apart and tried the lyrik damper. When the lyrik damper is fully compressed it measures about 20mm longer than the pike damper.Bummer!
Good info though, how did you find out?
