Spectral:On Fox float upgrade
Dhd12
Almería (Provincia)
I have a 2023 Spectral:On and thought I’d share a mod I just added.
You can buy the low speed compression adjuster thus turning the shock into the factory version minus Kashima. Takes around 15 minutes ( it is a little tricky) The cost around £30
Not set it up or tried it yet, need to get my ShockWiz on for a while.
I did mine about 2 x months ago after lots of research as some people say it works and some say it doesn't, my personal opinion is that at a minimum you should have at least 3 x extra settings as the the shock is set up with one of four settings under the cap from the factory, the cap has a small mark on the top to show you what it is set at.
