OneUp carbon bars review
I was very skeptical about these, thinking that a difference of one PSI in the front tire, or a fork service will have more effect than switching from Alu to Carbon. Eventually bought the Oneup carbon ebars and I think I can feel the difference, but not sure I would pass a blind test. The do look very nice on the bike!
4 months update: I'm really blown away buy how much these make more impact than I expected (I'm a mechanical engineer). Ride quality is definitely better. Not a game changer, but a nice upgrade.
I strongly recommend
Several years ago, on my 26er MTB, I swapped my Race Face Turbine alloy bars with Renthal Fatbar Lite carbon. My first ride was amazing! It felt like every single rock had had its corners rounded off just for me! The reduction in vibration from the trail was very noticeable. Three rides later, I didn't notice anything at all. I assumed the effect was still there, but it was now the new normal.
I am not denying the effect that carbon bars can have but I have never since felt the need to add carbon bars in search of that effect. Each bike I bought after I sold that 26er had larger diameter wheels, fatter tyres and/or better suspension and I never had vibration problems. All have had alloy bars.
As you say, it simply became the new normal. If you tried carbon bars again you would probably rediscover that effect, but perhaps to a lesser degree.
I have SQlab 30X carbon bars on my Rail and there is definitely less vibration transmission through the bars than there was with identical SQlab 30X alloy bars.
If your only experience with carbon bars are Renthal's I highly suggest you try some new ones from OneUp. The Renthal's are a very stiff carbon bar with not much flex so I don't really think there's much benefit to reducing vibration or hand fatigue with them.
It's good to know that the Renthal carbon bars are considered stiff, thanks for that.
But my experience with them was a good one. The reason I haven't tried carbon bars again was because I never felt the need, for the reasons I gave.
Shortly after I dialed in the suspension to where I liked it, I still wasn’t satisfied with the alloy bar feel. Seemed like every pebble was noticeable. I then switched to the Bontrager carbon bar. Barely any difference in feel.
I then threw on the OneUp carbon bar and cut it down to 780 mm. I liked it. Cut it down to 770mm. Perfect 👍🏻.
My relationship with every pebble on the trail is starting to wain. The feeling was noticeable to me and now I feel the suspension through my hands rather than the vibration I felt before.
Fair enough, personally there's no way I could ride with carbon renthal's or any alloy bars for that matter. At least not for more than an hour. I would have way too much hand fatigue. Too many years of arm pump from riding motocross I guess....lol
The moment I tested my new emtb with 35mm clamp, no name alloy bars and grip diameter for a child I knew I needed the One Up flex bar and super cushy Wolf Tooth Mega Fat Paw silicone grips!
The stock setup was completely unusable for my beat up wrists. No more issues with the new goods.
I’ve only been riding eMTB’s seriously for the past 4+ years. Thankfully I’ve made a few good decisions regarding upgrades, but I’ve made a few bad ones also.
There are three areas where my body touches the bike. Peddle, seat and grip. I’ve found that everyone has a different level of sensitivity to these three points of contact. I realize that suspension has a lot to due with the overall feel and that can usually be customized to suit my style of riding. But if the seat hurts, the peddle doesn’t feel good and the grip isn’t right, I start upgrading or trying something different.
The peddles were easy for me(I use magnetic). The seat(found a model). But the grip and bar was my nemesis. I eventually settled for the OneUp carbon bar, 45mm stem and Ergon Fat Grips. I adjusted the angles of my brake levers, shifter and dropper to a (hopefully) ergonomic position.
My hand cramps have disappeared …thank gawd. I don’t know what the magic bullet might be as everyone is different. It’s taken a bit of experimenting though. For example …I returned a seat only hours after I installed it. But my grips and bar type took longer.
rise and backsweep will prob have more of an effect than alu/carbon. You just have to figure what is optimal for you.
Got the oneup carbon bars on my bike now as well. Definately lighter then the stock alum bars. I don't really notice the damping it does maybe cause my old bikes had carbon bars as well.
Yep, way better feeling than my Renthal aluminum bars.
I also read somewhere that going to push on grips help as well for the hands so I tried some and they seemed to help over lock ons as well
Are those holes and channels for cables useful for anything but Shimano equipped e-bikes? Will they work with Specialized e-bikes with mastermind TCUs?
They're pretty clear on their website that the holes don't work with Specialised cables.
This is something that gets overlooked all the time.
I went through several sets of bars and had terrible wrist and forearm pain, after long rides on my meatbike.
Finally got a pair of Renthal Fatbars and combo of upsweep & backsweep eliminated all pain.
I'm lucky that my stock bars on my Merida are so similar to my old Renthals that I haven't had any pain, but there is a noticeable difference (it's only a degree difference, but I can feel it).
How to find an ideal combination of those with out expensive experiments?
There's a great video from (I think) Joy of Bike from a couple of years ago on YT.
They got some string, a couple of grips or bits of wood and did some measurements.
That was how I finally worked out what would work for me. I'll see if I can find the link
EDIT: Here you go:
Alternative perspective here, moved from Renthal Fatbar Carbon 770mm to OneUp Carbon after a crash with exactly the same rise and length.
Zero noticeable difference, and I pride myself as a very sensitive rider.
For full disclosure, I run a very supple 180mm coil Zeb, and had zero ride issues before.
I was running OneUp Carbon bars for years and while they do offer more compliance than others they didnt eliminate my hand pain completely. One thing that has helped massively was going to a bar with more back sweep, I used the video above and settled on around 12 degree back sweep ( I did also try 16 degree, but it was too much for me) and its helped alot.
I also use RevGrips for vibration damping and have found they have helped too.
So I would agree that rise/backsweep is more important than "compliance". Well in my case anyway. Everyone is different, just have to play around and see what works for you.
In the end it is very personal, it depends on your body, how you are positioned on the bike and what you ride etc.
I do agree that backsweep is also to me the most important part for my body position, this is the only criteria alongside rise.
What's doing absolutely nothing to me, meaning I feel no difference after I am used to the new part:
- clamp size 35mm vs regular: zero difference at all even side by side
- oneup carbon handlebar vs alloy: testing side by side maybe but once I pass few hours on both I do not care. I swtich from some bike with carbon some with alloy (not stock but great one), feels okay to me
- revgrips: tried them you can go crazy on settings, meaning they will really move more, but then you loose a bit of control and unless the whole ride is rocks I did not feel an improvement at all. Most of hand fatigue result also on poor bike tunning / rider / terrain (don't throw any stone to me I am not saying I am good at this either).
I also think that not everyone, unless you are a pro or very very good/experiment/babla, can feel everything from these products, sometimes it is placebo effect too, sometimes it is so marginal that the effect/feeling is pretty limited.
    Join 43,141
