Levo Gen 3 Lights wired directly to Levo motor / battery on Gen3
#1 thing to do before you turn the light on while powered from your bike is put it in “e-bike mode”. There are instructions to do it in the thread.
You will not get the max lumens out of the light in e-bike mode. E-bike mode reduces the power output of the light to prevent too much current draw which would trip the output from the bike.
Thanks. Is there a sweet spot in the Magic shine line up - e.g. "don't order anything more than '2000' lumens because a 3 or 4 or 6000 lumen lamp will reduce to this anyway"
Amp draw is the best indicator
Hi, then on e-bike mode has someone tried to turn it off, when not using the light, from the TCU mastermind display??
