M600 Fat bike hard tail frame.
Waynemarlow
Bucks
Hi, has anyone found a hard tail fat bike frame that will take the M600 motor rather than the more normal M620 motor ?
Hi, has anyone found a hard tail fat bike frame that will take the M600 motor rather than the more normal G620 motor ?
Nice, but still Full Suspension which on a soft 4" rear tyre in UK winter mud and slop, I'm not sure is needed. Sort of along these lines.
I lock the suspension on sand and on technical terrain and jump I unlock it and it's quite comfortable for the back
I just found this alloy bike, not sure how to find out who manufactures the frame though.
BTW: These are apparently the Bafang(?) cranks for M5/600 motors with a fat bike offset, I'd be curious to know which shorter cranks (160mm-ish) with lower offset (= smaller Q-factor) would also fit for M5/600 fat bikes. I was only able to find those (Miranda Q35) so far.
Just had another look at this subject, I still am not able to find any frame, besides the one I posted in my last reply.
There might be hard tail 29er frames, that can fit a 3.8" on a 50mm rim, but I also having a hard time, to find any other ones, besides the Lightcarbon LC1066 and the Dengfu E14, which both look like they won't fit that bill.
The entire website of the bike vendor is now down, so I can't even find the bike anymore. Would still be curious if there are any decent M510/560/600 compatible hard-tail-frames for real fat tires.
i had a good hardtail
its was a dengfu e14,was carbon fiber tho
i like hardtails but the e14 was a bit heavy with 840wh and m510 motor
i didnt find any other hardtail frames that i could consider building
maybe i get something like this for winter/ local trails
i wish they offer a frame only option
throw in a 3x3 hub and call it a day
could do that for around 4.5k total
    Join 43,191
