Update - AXS Dropper & Cockpit Changes
So the previous posts got me investigating my saddle height. It seems that my optimal raised position gave me around 20+mm spare that I could not use. So I investigated moving from 150mm to a 170mm dropper.
I absolutely adore the AXS drivetrain I just installed so naturally wanted to try the AXS Reverb dropper. So went and got one!
34.9mm x 170mm.
It arrived :
Straight away I knew I had a problem. The insertion shaft was around 20mm longer than the Fox Transfer SL Factory 150mm post.
I offered it up and it wouldn’t bottom out which is what I needed to get the right saddle height.
From investigation I found that the pivot bolts were stopping it in its tracks. It seems that there are ‘nipples’ at the end of them that prevents the dropper going further than the pivot insertion.
I took it into my own hands and got to work grinding off said nipples!
When installed and torqued I knew I had solved the problem - no nipples!
Installation was really easy and I paired it to the main AXS system.
From there I decided to tidy up the cockpit now that I had no dropper cable.
I wanted to lower the bar height by 10mm to get more weight on the front wheel. So I installed a 30mm rise carbon Renthal Fatbar (going from 40mm). Grips are temporary as I ordered GE1 EVO Factory Grips in stealth.
I also had to replace the heat shrink (which was a nightmare that resulted in a brake bleed!).
I installed cable tidy clips which the stem bolts slotted into that holds the cable in place. Making it nice and neat.
Performance of the dropper and the lower bars are great. I am surprised at how 10mm can make so much for weight distribution. Test ride at Degla proved some PBs.
Hard to describe the dropper performance but it’s so much better than cable operated. Very efficient and so quick to return to position. Feels ‘quality’
