Mastermind TCU display issues ( Fuzzy screen )
pgtips
Somerset
So this happened today after a light wash. No pressure washer used, just a light rinse with the hose.
I guess is water in the TCU. What’s the likelihood the screen would be back to normal after it dried?
I’d pull it off the bike then stick it in a bag of rice for a day or so and hope for the best.
Hello pgtips,
Did you manage to find the cause and solve the issue ?
Happened the same thing on my Turbo Levo SL.
And I'm currios to find out how can I solve this or if it gets worse over time or if the MasterMind TCU gets totally unusable at a certain point in time. So I should get prepared to what might happen in future.
Thanks!
Update on this.....as the bike was still under waranty, my local shop where I purchace it from replaced FOC.
Thanks for your comments.
Hello,
Thanks a lot for the answer!
Did they mention anything about the cause of the issue and what exactly got defective in the device ?
Did the new MM TCU2 device needed to be programmed by the local shop?
Or was it a straight swap ?
Thanks a lot in advance!
