Levo Gen 3 Issues fitting a RS Super Deluxe Coil Rear Shock on Levo Gen 3
RawSF
Bay Area
Recently purchased a 2023 RS Super Deluxe Ultimate Coil shock (210x55), shop said it wouldnt fit on my Levo Gen 3.
Any insight would be much appreciated. Is a custom linkage required?
Thanks in advance!
there is a thread somewhere around on what coils will work with the levo's frame setup. I would say if you can "clock" it so the reservoir doesn't touch frame during articulation you should be good. That thread also has some info on what coil's are "approved" and won't void warranty.
Apologies, I don't have a link for you.
Thanks in advance!
Standard shock fits fine. Not sure what the shop is doing but I would consider looking for a new shop.
I agree, look for a new shop. I just installed the same exact shock my gen 3 Levo and it fit perfectly. Just make sure to get the correct mounting hardware, m8x20.
    673K
