35mm rise handlebar
Lee c
Uk
Hi all looking for a 35mm rise handlebar to fit a 35mm stem, 780 width
Checkout the Deity Highside 35 handlebars. They come in a 50mm and 80mm rise. They come in 800mm width only but can be cut down. I was using the OneUp Carbon bars but they only came in a 35mm rise and needed higher rise. So far, I’ve been pretty happy. Good luck with your search.
Thanks mate that’s a great shout I think I’m looking for a ride around 40mm but not entirely sure, going to have to try a few I think, thanks for the suggestion mate your bike looks wicked
I ran the 50mm Diety bars on my Levo and liked them (Now on my Surron).
I later swapped stem and went with the 35mm One Up carbons. Found they were a bit less harsh in the rocks.
Another vote for the One Up in the 35mm rise version. They only come in a 800mm length but of course you can cut them down to 780.
I am impressed with how they compliant they are. At first I was worried about going from a 31.8mm to 35mm clamp size, as my hands are quite sensitive to vibrations, but they absorb vibrations even better than the 31.8mm carbon bars on my other bikes.
Thanks guys I’ve seen nothing but good things about the one up bars think it may be time to put my hand in my pocket 😂
Did any of you find an e-bike version with a crease in the bar ends to allow wires to go under the grips and into the bar? Or did you reroute the wires around the outside?
Another vote here for the Diety 35mm rise bars, have them on both mine and the 'better halves' bikes. Alloy but cheap as chips and proved to be bullet proof through numerous crashes. :ROFLMAO:
OneUp now has a e-bike bar that is compatible with certain systems. Edited to add: “Our Carbon E-Bar has internal routing for Shimano STEPS switch units and Bosch LED Remote.”
That’s the one I got, even though it’s not compatible with my e-bike. They’re actually very slightly (5%) even more compliant than their normal carbon bar.
RaceFace makes them in Alloy or Carbon. Raceface Atlas.
Thanks mate I had read that the race face bars gave quite a stiff ride on the hands ? Have you experienced this yourself ?
Running the One-up 35mm carbon ebar on the Rise & Joystick Analog 30mm rise on the Mega, I like the sweep on both bars. Think I ride them more rolled forward than others do
    Join 43,226
