Mud huggerOff topic but which mudguard is that you have there?
Mak,Well, i went ahead and removed the upper splined through shaft, re greased and inserted the correct way according to this thread it was in the wrong way, all put back together and just enough pre tension, it doesn't take much tension to make the shaft notchy .
I still have the creek although the bikes new so not surprised that wasn't the culprit, time for some more investigating when i can be bothered. For now i will keep riding.
There is one odd thing, it could be normal shimano motor rattle though. If i shake the bike gently side to side while holding a little tension on the pedals to eliminate motor free play there seems to be a rattle from within the down tubeIs this still motor rattle while tension is on the pedals or possibly something loose within the down tube ?
Usually if the rear axel (bearings) is moving under load the brake disk will let you know. Right?
so maybe not the rear axel?
I sold the Rise and got an S-Works Levo, so "problem solved".
Was the squeak that bad lol.
My creek/squeak/click is still hear. The bike only has 200 miles on it. Its not coming from, head stock/ any suspension linkage including rear hub / derailleur or axle. I've removed re greased and applied the correct preload to the crank arms. Pedals are new . To be honest all of it is still new and factory grease intact.
I have re done the pivot axles lower and upper and again all good and fitted correctly .
The bike is silent in every situation until the pedals are turned . I get that pedalling applies load to suspension components and will emphasise a creek by putting stress on components.
My bike will not squeak or creek until the pedals are turned while riding, no load just gently turning behind the motor it squeaks.
It creeks while not applying any pressure but turning the cranks backwards also
Its got to be motor mounts although all are correctly torqued up.
Mak, occasionally, my Rise gets a squeaking noise while pedaling. It only occurs if the motor has been exposed to a lot of powdery dirt. The noise appears to be originating at where the spindle enters into the engine case. My thought is there's some sort of seal to keep water and dirt out of the engine and the dust is drying it out. I've never taken an EP8 motor apart so I can't confirm this. I'd describe the noise as a high pitched squeak and irritating as hell. It only appears when pedaling, i.e. the spindle is turning.Was the squeak that bad lol.
Ročne som najazdil 3000 km. vŕzganie sa objavovalo a mizlo sporadicky. vymenene loziska, pouzivany loctite 368, namazane - a zase piska. Mal som podozrenie na skrutku predného tlmiča. Mazanie nepomohlo. Fungoval iba tlmič. Nepravdepodobné. ale čo ak?. Utesnený originál servisnou sadou a namazaný - zatiaľ je tichý.
Netvrdím, že som chybu našiel na 100%, ale ako vravím - zatiaľ je ticho
My creek isn't under load . If it was it would be a hell of a lot easier to diagnose .I had a creaking noise on pedalling under load. The mechanic in the lbs finally narrowed it down to the fact that the pinch bolt on the linkage couldn't be tightened sufficiently. He put a washer on, torqued it up and since then no creaking.
That's funny about the lube, but sucks about the noise. It would drive me frickin crazy.Rod, thanks again for your reply. So today i turned the bike upside down and removed the plastic motor guard giving access to mountings.
I have literary covered all moving and non moving parts in the worse substance known to man, ACF 50 via mist spay. This stuff gets into every nook and cranny and will eliminate any squeak for a limited time, even a fixed point between two surfaces on carbon.
I have been able to get the bike to creek in the garage by just sitting on it and moving it side to side with my weight on the pedals, i got the lad to train his ear to where its coming from and i agree with his ear, rear shock front bolt mount.
I removed it ( again) and greased hell out of its mountings and shaft, torqued back up to 6nm .
Quick 10 mile ride to let all that oil soak in and guess what!! Its still there
The creek is audible over the motor and is constant to my peddling .
I'm beginning to think its an inherent creek linked specifically to my carbon frame build and its a stress part of the frame that's creaking so at this moment in time I think I just need to except it and enjoy the company it gives me on my lone rides
On a plus note i have the most greased up oil covered new orbea rise on the planet lol.
That's such good news....Wahoo!Its gone guys, quiet as a mouse. thanks for all your help. I sold it last night .
lol. Only kidding. It was the rear shock top mount bolt / fixing . Even though i covered it all in grease . I removed it again and re installed, maybe this time it seated slightly different. What a relief .
I think the poor bike needs a wash / degrease next weekend, every where i look there's a slick of oil and grease![]()
Nuckaman,My Rise has developed annoying creak under load, read through the past posts regarding this. I will be taking it apart this weekend and rebuilding the linkages. Regarding Loctite and the pivot axle. Is the Loctite applied in the middle/smooth section of the axle? Really?
Yes it was…if you have question on the service, shoot me a message, I’ll help you out.Thank you for the details on the service. Even with our overcast and morning moisture, definitely lot of the trails have dried out significantly and the moon dust has returned. Hero dirt was awesome while it lasted!
The 2023 Rise has a new rear shock yoke, linkage arm and upper pivot axle design that is different from the older 2020-2022 Rise models. Unlike the 2020-2022 Rises, Orbea also added axle seals to the upper pivot axle to keep debris out.Seems like the 2023 carbon models are having less problems, regarding towards problems with the suspension/ bearings … or it’s maybe to soon to make these conclusions?
638 isn't grease, it's Anti-Grease! It's a retaining compound.... Glue effectively.... Used for stopping bearings moving etc...Resolved the creak issue following the details in the thread. Thanks to Rod B for all the excellent the info.
I used Loctite 638 as prescribed but wouldn't high-pressure industrial bearing grease provide the same service? I would think a little thicker viscosity grease will stick around a little longer than the 638 stuff. Either Orbea forgot to apply it during assembly or it thins out with time/use/washings because mine seemed to be dry as a bone when I took the linkage assembly apart.
Nuckaman,Resolved the creak issue following the details in the thread. Thanks to Rod B for all the excellent the info.
Rob,The 2023 Rise has a new rear shock yoke, linkage arm and upper pivot axle design that is different from the older 2020-2022 Rise models. Unlike the 2020-2022 Rises, Orbea also added axle seals to the upper pivot axle to keep debris out.
Hopefully the new design will stop linkage arm/axle slippage and require less maintenance. Wahoo!!!
LParker3,Rob,
Do your tech papers apply to the 2023 linkage?
I'm trying to eliminate some minor creaking noises.
