Rail (625Wh) Rail with centerlock hubs
JuSiZ
Finland
Hi. Thinking to buy new dt swiss wheel set with centerlock hubs and thinking what kind of rear brakedisk magnet will work on rail?
One that you glue on.
Yes i know it works allmost every magnet but i mean some ready product. Looked some shimano disks with magnet but will it work out of box because i see there are different option on magnet location/dimensions.
I refitted the shimano magnet to some TRP disc's when I replaced my rear wheel with a dtswis one.
Just used a round file and drilled a couple of holes for the mounting plate.
oddly theres a discussion on the FB 'Trek Rail Owners Worldwide' group started a few days ago about this :unsure:
theres a few options but easiest is probably the Bosch offering
p/number 1270015727.
as example it's £15.49 from TBS Magura Rotor Sensor Magnet. For Centerlock (BDU3XX, BDU4XX). 127001572 | Total Bleed Solutions and may be cheaper elsewhere (I didn't look🥴)
also, if you're using Magura mdr-p discs (203mm I have seen n my mrs's Orbea) have a hole in the ball suitable for a magnet to be inserted into, obviously you’d need said magnet that’s conveniently also available as an extra from Magura (~£10)
Rich.
