Kenevo SL KSL Comp brake upgrade recommendations
Myalteregohamish
Vancouver, WA
I was thinking about upgrading to Saints. How big of a deal is it to route the new hose through to the rear? Is it tube in tube all the way to the rear and it's no big deal or is it a drop the motor type of thing?
I'm in the same boat as you. Did you already do it? I am curious if I need to drop the motor also
but I thought you could run it all the way.
On the SL carbon frames there should be a inner sleeve all the way from the back port to the headtube
