Large or extra large on the vitus esommet vrx
beanzz
United Kingdom
So, I'm 6ft 2 (187 ish cm) which puts me right in the middle of the sizes and I was wondering whether I should size up or down, I assumed down because ebikes are rather heavy and stable so a bit of extra playfulness might not be a bad thing but🤷🏻‍♂️
Any advice would be appreciated
Oh also the vrs or vrx? The vrs is in stock rn and I assume it would be cheaper to replace parts and etc
Hard one to call, I'm 191cm on the gen 1 XL, the gen 2 L and XL are either side of this reach wise though. If most of your riding isn't hitting chunk at high speed I'd likely go for the L, you might need to run a 50mm stem though as the ST angle on the gen2 is steeper so might be a bit cramped when sat down pedalling. It should feel quite a lot more playful though
Alright thank you :D that kinda mirrors my thinking
