Slapbassmunky
So, 5 miles into today's ride on my 9.8xt the speed readout starts going all over the place, with the motor cutting in/out and misbehaving as you would expect, but NO fault code. So I stopped, bashplate off, and unplugged the sensor to at least get home in limp mode.
After testing the sensor with a basic multi meter it gives several pulses per sweep of the magnet. Confirmed with a hand held scope. The reed switch is kaput. P/N W582244. By some miracle the local dealer had one in stock so all is good again. However they did say the failure rate is very high for this particular part, and it's a Trek item, not Bosch. They are a fairly long lead time, and I'll be keeping a spare with me at all times.
The local shop is working on a solution using a butchered Trek mount with a different Bosch sensor potted into place.
What are people's experiences with speed sensor failures?
