Rail (625Wh) 213mm bike yoke dropper
Geedog
Shillington, Bedfordshire
Hello, has anyone on here put a 213mm drop bike yoke dropper on a large carbon rail? I have a one up 210 fitted, but it has a lot of play and doesn't return fully every time, I have to pull the last inch or so now n then. Pics would be appreciated if poss. Ta.
Have you had the one up for a while ? Sounds like it needs a service you can get service kits for them. Its pretty easy to do.
or even try just unscrewing the collar with a strap wrench and pack it with grease
and check air pressure, 250 psi iirc
Hello, Thanks for the reply.
I have done the service about a month ago, it was smooth up n down for a week or so, but it's still floppy side to side, and is no longer smooth on the way back up, I've checked the air pressure too.
I've ordered the bike yoke now, so il find out if I can touch the pedals soon.
    675K
