New 2022 Rise H30, Rear wheel Hub question
California
Ive seen the rear wheel comes with a wack rear hub.... without a new wheel set , can the internals be changed on the included hub to beef it up? Trying to prevent the issue ...if so , whats the recommendation?
Not sure what you are talking about. The H30 comes with a cheap shimano hub or a Chinese equivalent due to supply chain issues. Both cheap hubs.
I'm aware that's why I'm asking can the internals be changed without the expense of an entire hub replacement?
By internals if you mean can the guts of another hub be swapped in I doubt it but I never use anything by Shimano. I built new carbon wheels with Spank hubs on mine. You can definitely swap the hub but it may require new spokes and a wheelbuilder to re-lace the wheel. Many threads do note a short life for the orginally supplied hubs.
Thanks , I was trying to be proactive, Ill look into a rebuilt hub at a local wheel builder
The Chosen Hub on my 2022 H155 lasted about 100 Miles. Waiting for a steel plated hub from Spain now. Had I known about this issue would have upgraded to a premium wheel/hub at time of purchase from LBS. Otherwise great bike! I guess they don't know which bikes have this issue.
There was no way to know since it was a supply chain substitute to get the bikes out the door. Even the Shimano hub originally speced where cheap hubs. I built a new set of wheels with carbon rims and Spank Hex hubs before I got my bike.
I just got my bike two weeks ago, 22 h30 new color..it has a Shimano FH-MT510-B rear hub... hopefully this is a little more durable since the supply issue has been mostly resolved.
    675K
