Rail (625Wh) Rail 5 RockShox 35 Gold RL Fender mounts?
Coatezy
South West, UK
Just ordered a Rail 5 which will
be my first EMTB and full suspension bike. I was hoping to fit a RRP Proguard front fender, ideally without cable ties. I am also going to grab a ride wrap PPF kit for the frame and forks. I see that there is a variant of RockShox 35 Gold RL that has fender mounts, does anyone know if the Rail 5 comes with this variant? Based on the photos I’ve seen I’m pretty sure it does not.
I'm pretty sure the budget forks don't have the threaded inserts in the rear arch of the lowers, would be a cable tie or RRP velcro strap jobby unfortunately.
Hello!
I own a 5 as well, my best solution was the common "zip tie on" fender for fork. That RRP looks good though
It sounds like that is the approach I’ll be taking too unless by some miracle the latest bikes use the fender mount variant. 😄 Think my safest bet is to wait for the bike to arrive before I order the fork PPF. I’m bound to order the wrong one if I don’t.
Yeah that was my original assumption but there are versions for sale that specifically say they have fender mounts and are also visible in the photos, in fact it seems to be the EMTB version that have them. Trek is probably using the non-EMTB version.
Steerer tube mount.
Warning:
This front fender mounted on a Rail may cause excessive wear to the lower face of the steerer tube/headset because of the slightly larger diameter of the Rail headset.
These were the first fenders I purchased and installed for my 9.7 Rail. When I removed the fender (for cleaning) I discovered paint-wear where the fender touches the steering tube. My fix was; remove the front fender permanently and cover the wear area with clear heli-tape.
I was not friggen happy…this was my first blemish.
They may have addressed this issue since, but now I don’t use a front fender at all. If this model of fender is installed on your Rail …check the clearance.
Warning:
Gutted
Fair damage from riding i can handle its part of the sport we are in But when its damage like this it really bugs me i feel your pain :(
Warning:
That is frustrating, thanks for the warning. As I’m PPFing the whole bike I should be able to safely fit a guard with cable ties without any rubbing. 🤞
    673K
