@steve_sordy Thx Steve, I can always count on you for your great posts. I copied your notes and put it under "Flats" in my iphone notes.
When I got this last flat I only broke down one side and pulled the tube. Which was a mucked up with Muc-Off because after the LBS could get the non TLR tire to stop leaking . . . I said put the tubes back in. So he stuck the tubes in without washing off the Muc-Off. When I went to patch the tube it was a mess as I had misplaced alcohol wipes that were supposed to be in my emergency kit or sand paper. I had to scrape the tube with my knife. Then after I started pumping it up again it would not hold air
. I did first put in the spare tube but it was a cheapo Goodyear from Amazon and the valve was bad and worse not removable! So I was in a higher crime section of town and I called my wife to come down with the SUV asap and get me outta here!
Next morning I took tube out and it had a second hole of course. I would have found that out when I was at the spot by pulling the tube out again and checking it but I had pulled off to where some contractors were working (so I would not get bike mugged) and they were throwing me out as they were closing their gate, so I called the wife.
As to one of your points about the examining the lines around the rim . . . that was exactly my problem when I tried to install the Goodyear tube again in the AM. The one side the bead was never broken so that was even all around. But the broken side I could not manually get the bead back in place after inflating. I let the air out again and still uneven. My issue is I love the tread pattern on these Bontrager LT4 Expert Reflective but they are not TLR. They are non foldable wire beaded tires. Even the LBS could not get them to seat and not ooze air for two days. I know you said it may be slow to seal, but I have sometimes have to pass through some bad inner city areas to get to the trails I'm heading too which most are only 3 miles from my house and I can't take a chance on losing air at a bad area. The other issue I found when I tried going tubeless the first time around is these Bontrager Line Comp 30, Tubeless Ready rims have this fine lip on the inner side of the bead channel (pictured) that hampers the bead from popping in correctly.
So I finally said screw it and took it to my Trek LBS and he installed an $11 tube and charged me $16 to install using his high volume compressor.
These
These $45 2.5 wide Bontrager LT4 Expert Reflective I've grown to love the tread pattern. They suit my riding style. Fast rolling in the middle for hardpack, streets and bike paths, yet still somewhat knobby on the sides for single track gripping. The tubeless versions have different tread designs. I have two Ebikes. My Giant has 2 inch tires and more suited to road bike cross counrty trips as they are really fast rolling and it has a top speed of 28 mph assisted. When I first got this Trek Powerfly I could not stand how draggy the tires were so I swapped them out for tubeless 1.95 tires with a fast tread design. First time trying them I was doing like 3 miles an hour coming off grass onto a sidwalk and the rear tire slipped out and next thing I knew I was on the ground briefly unconscious. Thanks God I had bought a MIPS helmet. I shock it off and rode home. Tires came off at the LBS the next morning and they put the OEM back on with tubes again since they could stop the leaking when tubeless mounted.
The LT4's also have a Kevlar layer, so I figured that would help with small punctures but this was from a 2.5 piece of scrap aluminium that I pulled out of the tire. If it was tubeless, I doubt if a bacon strip could have stopped this leak. I used to repair tires as a kid in a gas station next to my house. I used to use bacon strops and plugs but they would vulcanize from the 65 mph heat when driving. I don't trust bacon strips in a bike tire. I'd rather patch the tube.
So you brought up a lot of good tips re going tubeless, but my bottom line is until I can find a high volume compressor for home use I'll stay with tubes. Botranger makes a one shot blaster one for like $165. And I've read about the others and most have too many negaitive reviews. I'm not paying LBS's to mount or repair tubeless. But I need to find some type of reasonably priced high volume compressor first.
