2019 Levo Seat up graded.
mark harris
New forest, Hampshire
To WTB Pure Race Saddle .
Been out a few times now for three hour rides and found the seat a lot more padded and forgiving on the ass!
i like the way it scoops up at the back , makes you feel allot more locked back into the seat.
Few photos here of the seat.
Other up grades which work really well for me.
EXT shock
TF Tuned forks with coil conversion , giving me 160mm travel.
38 front sprocket
Brakes / tyres.
y9GUUGEzCmm_LXywsKSJCzUQ5WghXaoCqZg81PHn5OD3-o56pxW8NQd3XFOthaOfeVZzszy6IpoCaWY6DPnfeUFHvBCKQ8Hw6u5J5jJeAsH-T7Utxiv-Xfr0PA5i3eybfwF9tX1Ta-6vK_Xt2PZFHQsq2uz0vArk1LHNxd5Bv-vK5URKoDP5pNEQNQEL1dLdPooeCJ34Qqlm1Qug9v0IkVqqIbVB_B8MKlye5xGYeCyO0ZGiuaZWxYWgaWmI2zGAXrMePoq0tH_SaOxVWjhRRZ4cC0jJBWmxXoAU_T-ecnVeyByBIl-19d1y7B6sjJvpIHcpl7Z0HO_8IJzlhUkpz1EF3LrAV19KzAdZLkqjbHrtzNu91Ku9E3pBJU3CVwRSG-hV_eMEC_46qp9ulxGqTyariGMh76AM7AvS6-nQeElLkQA8i4QyKMedrT5oOHu58EGS7ZXph_zgiTNb2LKE699tB4z8qvN1eVjVDqBIQsBcWD0bnujrAGpN7ar_-48is8qOaKH_2PkEZIciriBUUtXFiERyfRtCWEjud3qEbP-b_OMeQ9cYA7f4_M2G3Kb3T_CHCDuMFGkBlUsFiqZVJ7qPBqybo_nALJlK_CyPKTioUUtohCRzrqUBCTffhf5yZaD0N_1RPwdN4XtNuGDLLU08Iw=w1595-h897-no
DAKynVepiyntGRYOt2gPu0SoTVPEkyJlL_Pk-Ayx2R7oE4AjA0BtFmUO72zKPtpAFed5_yw7i32bzEuL17vy2Xn4PtnrrqpIx2UVYvb3ZVuVQ5Id80fXeAYc-Cxi-ISmkmpKCN25sb2uo10bfiLt--pwitPZZVQA1o6XwLmM3E2x_iiHSA7SGgiwZGKPUJpDwwpoDV1jf7sSYF08TV7GAIf6_iUblGndl6ebdWaPm4vuZCEzSt9IyeIKKMQMsrBqPIgHFh_SFQwUpSEII2UiG-JhfVJHk5cEqIHCnSxICxAxWaikdSH4AzQ2QjDFJud6iSBM50GsIHZfnSBdWsMY29opO8E-m-KOHiLLKsWnO8OZtbHpm2GF-1VPmY7boxMFp9F6dO5dJygflxY8WB9XpZK6wLTeEmQrj4cr0-A8_2DNgHhEEsqa0psVifMD_fr93M0EHbtPqjgSKKLOlz4Gbb9os0Hy5_y_SCk7j_AcI5s0xIVwij_r_gRJ_Ndk4WlmvBXF4E7PjpS1heqL14NLVm4bjuOtS-C2Bk7sqx77zlIFEsydEGZXqsNO_wMLM2uYN6imfQgBiOVc2TrGi27rAZzWxnQIj0akCfLd7HHAmlydxxPHgMHJsp4PyNej8GDWiilQR3OgRqGd17chNdewH8FNCA=w1595-h897-no
Did you get time on the standard shock? How does it compare?
Is it me or is that stem really long?
Only 10mm longer on the stem, to get me over the front wheel a bit more.
The EXT shock takes out all the smaller bumps, no bobbing about and grip is better on all terrain.With the coil fork set up there is a lot of grip every where.
EXT shock
38 front sprocket
Brakes / tyres.
Same here funnily enough. Gave it one decent outing on the Specialized saddle, but had a sore arse after so got a wtb one, which is much more comfortable, especially as I'm now riding 3 times as much as I used to!
    673K
