Rail (625Wh) How to access the cables behind the alignment plate
Haptic
Hi, I have a Rail 7 (2022 model) which came with the battery alignment plate. I want to replace the seat post clamp so I need to lift the dropper post out of the tube so I can slide the clamp out sideways through the cable. To do this, I need to loosen the cables brackets so I can get enough slack in the dropper cable to lift the post up and out of the tube. Question is, how do I access the cables brackets behind the alignment plate? Do I really need to take the whole thing off?
On my January 2022 Rail 5 (500Wh) the cables are on the opposite side of the battery alignment plate (which is fitted to the lower side).
(The bike was supplied by Blazing Bikes in Shropshire, UK).
    675K
