Levo Gen 3 Starting points for suspension tuning on S-Works Levo
RickBullotta
I couldn't find starting point recommendations for damping settings on the 38 Factory and the X2, so I was going to use "experience" and the Fox baseline specs. Anything special with the kinematics on the new Levo that you'd recommend tweaking those recommendations? Obviously I'll use the performance on the trail as the real indicator, but wanted to get a solid baseline to start from. Weight is 172 lbs BTW.
Thanks!
    670K
